supercharge/ tucked harness build
The cobalt has a SAAB Forged Engine that can take over 600 WHP without modifications...
This does not...
On the Lsj motor(05-07) I believe seen maybe 500hp then it's risky they said but true on the Mazda not having an oem motor as strong
Was not saying its as easy was just saying that it would be like they do with the cobalt SS
Never seen or heard of a twin charged Mazda that would be sweet
He said hes gonna build the engine would be perfect 7 psi of the turbo and 7 psi of the supercharger Would be a fast car with a good tune all u would need is a msp turbo setup gt25r will be fine with a fmic upgrade 3in turbo back and aftermarket mani.... I would first get the car running with the supercharger well then add the turbo
Normally you would twin charge because one or the other alone would or be capable of producing the volume of air you were trying to jam into the motor.
I can barely use a GT30 to its potential with what might be the most completely built protege on the forum... adding a supercharged will simply add drag to the engine and or make a fancy car that gets driven at 2% throttle on a trailer to a show...
Get either a SC running well, or a GT28 / GT30 running well
Either way, the OP should forge the motor IMO
I can barely use a GT30 to its potential with what might be the most completely built protege on the forum... adding a supercharged will simply add drag to the engine and or make a fancy car that gets driven at 2% throttle on a trailer to a show...Get either a SC running well, or a GT28 / GT30 running well
agreed
i
Actually there is a 247 member with the aai kit and turbo setup already ill see if i can find it all i knw is the supercharge is used for low boost and turbo for high boost
I think just forged block would be fine right or should i do the head as well
The nice thing is your supercharger mounts on the intake Mani all u would have to do is build a msp kit around I recommend that when u add the turbo upgrade turbo mani the exhaust to a full 3in and a custom fmic
Its the aai kit they where made for the ford lynx
Where did you get it?
Ah, I found their site ( AAI ) where you can still purchase it. Has to be translated but its 98000 yen or about $1253.
Not a bad option to get you in the range of the MSP. I'm interested in your build.
More work done and few more parts
Here is the proper engine harness finally i will wire tuck this
My custom gauge pod no over lay
Gutted old nasty grey interior i have all black interior going in soon even speed dash
Battery will be relocated to the trunk so my meth kit can be mounted in engine bay
Gutted trunk going to make amp rack soon
Old interior
Hole in floor
Sr motorsport cam gears
Nology kit
Pioneer double din, rockford fosgate subs, capacitor and amp
626 manifold ported going to clean and smooth it up then powdercoat black
Meth kit in a hot engine bay... ?
and you can think about the battery on the other side to offset your weight,
What's the point of spending a bunch of time on the 626 mani. It's just goig to be pulled out anyways isn't it?
Yea but not any time soon i still have forged pistons and rods to buy plus something to tune and all gauges plus i need a better tranny. So in the mean time ill prep the manifold and sell it later.
Motor build coming soon parts are on the way stock oem setup for know 84mm pistons, knife edge crank. Port polish.
