Group Buy: 505 Intake Manifold Round 2
Status
Not open for further replies.
Oh hello... late night delivery ftw.
The batteries in my scale are toast, but the new floor plate design definitely shaved some overall weight. Even with the EGR flange on there it is a lot lighter than the first batch manifolds were. I'll get a measurement on that tomorrow while I test fit it.
I will also be checking the clearances as far as injector diameter goes. I don't want the new mount design to cause any issues there.
And do you know the location of the 1/4'' npt port for the vacume line cuz ill be using a catch can for the pcv
I'm eager to hear if the install was perfect. ��
It was. Only thing that changes during install is you now MUST attack the 2 middle upper bolts from the bottom. This was already how it was normally done when the fuel rail was pre installed. A gear wrench works or you can do the turn/flip/turn with an open-end. Everything else is perfect and you guys are going to love these things.
Status
