Yeah so i only changed the pipe that goes from the throtle to the intercooler and it was running fine idle then went to test drive it, would stop stalling, put back the stock pipe on and now all it does is click and wont start at all, but it gets power... basicly its a dead peace of s*** and i have no idea what its issue it... didnt do all pipes ect, for the fact ive never worked on a turbo before and there was to many sensors for me to play with... and now i have a yard orniment...
Ok so what is your setup? Is there a blow off valve on the pipe you installed? If so, it will cause the car to stall unless you relocate the MAF sensor between the BOV and throttle body.
Survived Tail of the Dragon... 976 miles in 3 days... then on a small straight away... blew a 5 1/2in hole in my block right above the oil return line behind the turbo :(
Did this today.....
