Guys been awhile since an update. Car now has 3,000Km on the new engine, a few upgrades have been made. I'm currently running (a modest) 15psi, and this thing ***** right off. With al lthe upgrades done, 15psi feels like 22 did on the last build. I think it's mostly the head work and the cams. I've changed plugs once, and I'm now running Mobil1 15W-50 Synthetic now that the break-in is complete.
So, since the build was completed, I installed a new deck (unremarkable) re-did the fuel system (again) and completed the PCV system with the help of a second vented catch can thanks to forum member Signature Sound.
Here are a few pics of the various upgrades since the build.
Removed the intake side PCV nipple, and drilled and tapped for a -6AN fitting.
Drilled out the interior baffles as big as I could go for maximum flow:
A shot of the installed can with black fittings and line:
Although the stock 1:1 rising rate FPR is great, I broke mine trying to convert it to an AN fitting setup. Decided to say **** it and go with an Aeromotive rising rate adjustable regulator. Mounted it to the firewall, and installed a pressure gauge. I realize that this gauge is a bit redundant (I have a liquid filled one right on the rail as well) but whatever. Ran -6 lines with all black fittings. The red accents on the line are a nice touch. The adapter for the perrin fuel rail was actually a spare oil feed fitting for a T4 style turbo that I had lying around. Bolted up perfectly, and the gasket worked like a charm.
Excuse the iPhone pics, but here is a shot of what I hope is the finished engine bay. 8 years in the making, and I think I can finally say that I'm happy with it:
