i figured this so actually i removed my WBsensor while i used the seafoam in the brake booster... it also help me find large cracks in the exhaust mani that i couldnt see because it was under the runner... the car did run nicely after doing brake booster/gas and oil. just remember to change that oil lol
Well I read straight from the website that you are supposed to use it about 100 miles before your next oil change. But as far as 02 sensor go, the one in my manifold is about 2 years old and I bought it used LOL and my WB sensor is probably nearing 2 years as well. I honestly think it will be okay since they have survived the pig rich condition that my car has been in for as long as I can remember.
ive done it both ways. the brake booster will give you that lovely White Smoke that everyone gets using the seafoam :)
Mine didn't.....and I did it when I had 190k miles......no smoke.
Ill probably do it again when I put the new turbo in.
I changed the rims and installed FMIC
I may be the only one that prefers the black around the doors... my friend has yellow MSP and it to me doesnt look as good as my yellow one due to that.
No I like it all black around the windows as well. Doesnt look right without the black there to break up the body color some.
If you add it to your crankcase prior to an oil/ filter change then you need to change the oil within 30-100 miles. If you add it to your crankcase after an oil/filter change than you need to change the oil again within 3,000 miles.
When you do a top clean or add it your gas tank then there is no need to change your oil.
I think its bunk that Seafoam killed either 02 or WB sensors. Most likely something else did. I use it in everything I have. My MSP has both original 02s and its been Seafoamed a lot over its 86.7K miles.
i like the vinyl removed look around the window/doors... as for milage im creeping at 144k... tis why i think my stock turbo finally failing lol... still have stock bpv though :)
