nightmaresk8r45
- 2003 mazdaspeed protege
like it says. im done with my protege and returning to the honda scene :] heres my specs. 2003 mazdaspeed protege, mica orange. bought from the original owner in november 2009 (he was a 62 year old man) bought the car with 123k. at 126k the timing belt water pump and valve cover gasket were changed. i also change the coil packs, wires, and spark plugs, egr valve, brake rotors, and a few other things that i cannot rember. car currently has 144k on it. i will compression test it in front of you to prove that it has perfect 210 comp. acroos the board. the motor is 100% healthly. the body is in decent shape. its rusting in the rear corners like a honda but this is bc the original owner did not care for his car. interior is fine. only thing missing is the oem sub and amp. mods are injen sri, custom fmic setup, and a j pipe back side exit exhaust that has no cat. the car comes on steel wheels and heres the kicker, its got a broken passanger side front axle so you would need it towed. and thats everything i can think of right now. my number is 973-202-8611 and i live in north new jersey. give me a call if interested im asking 3000! obo!
