Ok, need some help from you guys. I'm going to pick up an ebay hardpipe kit since they cost nothing and do hardpipes for my MSP. So I need to know these measurements to know what couplers to get.
The hardpipe kit is 2.5".
what are the diameters of these:
Turbo outlet(hotpipe): 2"
Turbo inlet(intake)
SMIC inlet/outlet:
TB: 2.5"
MAF: 2.75"
Thanks!
im about 95% sure the intake inlet is 2.5" and I know the smic inlets and outlets are 2" also
Also, I plan on relocating the maf to run a BOV. Is the T that the stock BPV uses strong enough for that? If not, how should I run new line?
get a vacuum manifold and run it off the brake booster, loose the T and run just one dedicated line to the WGA and one to the BPV. I can make you a mani like mine Taylor, I'll send you some pics if you want.
Awesome scott, That would be great :)
do you just plug the vacuum line that the T was coming off from then? Guess I should run my boost gauge from the vacuum block too eh?
ordered my secondary 12" slim fan and a 40a relay to wire it in. also picked up a wbo2 sensor for $56 brand new. gonna put that in later today
ya my bad, I had a feeling in the back of my mind that it was 2.25, but I just didn't remember ordering any (which is really because I just used a 2.5" T bolt clamp, and the couplers came with the Injen kit, sorry about that, but the smic are definitely 2"
I just replaced the wga line with a bew one. No couplers. Running bov off brake booster without a block.
