Whatcha tryin to sell? Anything else I could use?
Mainly a bunch of misc. stock RX-7 stuff. Most of it is stock suspension and body stuff, which I don't think would benefit you at all.
FINALLY got the flywheel nut off! Then I had to get the flywheel itself off, which was another task in itself but some progress was definitely made today. I'VE CRACKED OPEN THE MOTOR! Pictures and captions below...
First, here are two pictures of the engine in "short block" configuration; literally three "irons", two rotor housings and the rotating assembly:
Next, it was only a matter of slowly and methodically loosening the 18 torsion bolts that hold the engine together. First the rear "iron" was removed. Nothing looks suspicious so far:
After that the rear rotor housing was removed. Everything still looks good to me besides the copious amounts of oil (is that normal?):
Finally a look at the rear rotor and intermediate "iron". All seals on the back face of the rotor are intact but what's that on the iron?
Let's take a closer look. I'm not really sure what this is but it looks like some coolant seeped out of its cavity and mixed with engine oil between the housing and iron. I still don't see evidence of a combustion chamber breach but I will take a closer look later:
After that I decided to temporarily put the engine back together until I could clean the garage some and develop some sort of organization plan for all the seals, etc. I cleaned the garage up a bit but I didn't feel like messing with the engine anymore today. Instead I tackled the rest of the A/C. All remaining lines, the condensor and the evaporator have been removed from the car. Now I just need to find caps for the lines that go into the car.
That's all for now. The next step is literally to pull the entire engine apart, clean the components and start the inspection process (need to pick up some more tools).
