WTB OEM front cat 2002 P5
Status
Not open for further replies.
Will2k2p5
2002 Mazda Protege5
I live in CA and in order to pass smog, I need an OEM cat. Originally my car was from Michigan and a hole rusted right through it. Please PM details.
Thanks!
I have one in good condition. I live in Hawaii though but if you want we can work something out. Pm me info. Thanks
Thanks!
I have one that I just took off of my car I live in miami fl so I'm not sure what the shipping would be probably threw the roof sence it is cast iron and ways about 10 to 15lbs I can check how much shipping would be and get back to you. Send me a pm with your adress and we could work something out thanks
Do they just check the computer there, or do they use the sniffer? If it's just a computer check, you might be okay. If its a computer and visual check, I'd put on some high temp tape or something just for the test and take it off as soon as you're done. These cats are everything but cheap.
Best of my knowledge, they do a visual and computer check. High temp tape might do the trick, but I doubt it will stop my computer from throwin a code for an exhaust leak. Regardless, I need a new cat because my car sounds like an STI with a crazy sputter when I shift. I did a little research, and If I can't find a killer deal through a forum member, CA does up to $500 in assistance to help with smog repairs(if I'm accepted).
*EDIT*
Pepepingo and Jason, I PM'd both of you but it's not showing up in my sent box. Not sure if you received my PM's or not.
Zip code is 92117
I can get an OEM cat here for 920 from the dealer(slight discount) while an aftermarket is merely 200-300 at most. Not really sure what my limit is, so please throw an offer my way and I'll see what I can do.
Thanks guys.
Status
