I noticed that whenever I turned the heater fan ON to any of the 1 through 4 positions (A/C button is OFF), both rad fans would kick in for a few minutes. After a while they will turn off, and then back on again shortly after that. I touched the cold pipe from the compressor, and discovered it was ice cold. So, something is causing the A/C system to kick in even when it's turned off.
When the A/C kicks in by itself like that, it only cools the air by a bit, I noticed. I do have to actually turn it to ON position for it to blow cold air full blast, so it would seem that even when it does come on by itself, it doesn't come on fully.
For the time being, I took the A/C fuse out. Compressor doesn't kick in anymore, but the both rad fans still do that ON/OFF dance whenever the heater fan is ON.
Couple questions
1: Any clue what's busted that's turning the A/C ON whenever the heater fan is in any of the ON positions.
2: This rad-fan on-off cycle (both of them at the same time), that's related to the A/C coming on by itself, correct? I mean, normally when the AC is off, should both fans kick in like that (to cool the coolant in the radiator), or does normally only one of them kick in?
I don't get any CEL
Couple questions
I don't get any CEL
