Tenawesome Parts: Steedspeed, Turbolife...
Status
Not open for further replies.
just_B
Lava Orange
Paypal: bkshearer@gmail.com CONSIDERING BEST OFFERS
Steedspeed, ceramic coated, new never installed. Gaskets and an egr pipe. I also have a set of studs and nuts for the heads so you don't need the bolts any more
$600 + shipping----SOLD
Turbolife FMIC, Maf relocation, hose adapter to use a Bosch type blowoff/bypass valve. iNJEN coupler not included
NO FITMENT ISSUES! Did not hit fan and pipes didn't pop out.
$650 + shipping----SOLD
Injen Cold air intake, unused filter, all hardware included (pipe w/green tape not included)
$150 + shipping------------SOLD
ECU extension harness
$75 shipped------SOLD
Perrin SS exhuast sounds awesome, an exhaust hanger on muffler needs welded. Have a silencer for it too
$450 + shipping------SOLD
Perrin Foam Filter, simply delicious
$35 shipped
Kartboy shifter bushings
$20 shipped------SOLD
Dual pod a pillar 52mm: Painted to match interior trim. Gauges not included. Does have a portion of an a-pillar up top for easy install and keep original a pillar in great shape
$40
Dual pod a pillar 60mm: Primered, for 60mm gauges
$25--------SOLD
FS Cylinder head: Low miles, 45K
$100+ shipping
NGK Stage 7 Copper Plugs: Stage colder than regular MSP spark plugs. Brand new, never used
$10 + shipping SOLD
K&N filter: Used with adapter on to turbo, low mileage, about 2k. Have the squeeze lube to go with it.
$20 + shipping
Stock intake manifold: All there, no cracks
$75 + shipping
Turboxs Bypass/blow off valve: was vent to atmosphere no issue and recirculated no issue.
$50 + shipping---sold
Set of Cams: From a Protege, great for a custom regrind or whatever. low mileage, 45k
$75
Mazdaspeed Flywheel: Great shape, lighter than a regular Protege, no bluing or burnt spots, rust comes right off, only surface rust
$125
New Coils: Set of new coils, haven't used
$50
Spot for Pope 3" Dp: I have a spot on the 3" dp group buy, look at the thread, I'm there, I promise
$107
has resistors to add 100hp.
It's so you don't have to cut factory harness for standalone/afc install
How many miles on the shifter bushings? Do they go in the bottom of the shifter or on the trans?
this is a good guy. and iv e seen all the parts in person they are all good quality pieces. just wish i had the money for the steedspeed :/
Status
