tommyleeyyz
- 2006 Mazda 3 GS, 2008 CX-9
Hello,
Hope someone can help with this issue. I did a lot of searches with various word combos, but the closest I could find was a to-do list after battery is reconnected, but it didn't mention anything like what I am experiencing.
Vehicle:
2008 CX-9 Touring with Assistance Package + Factory Remote Starter
Symptoms:
I had to disconnect the battery while installing a DRL module--I am very certain that the module is not the cause--you'll have to trust me on that.
After I finished and reconnected the battery, now whenever I open the door, the following items flash in sync for exactly 1 minute then stops; the timing is similar to the hazard activation, but it is not the hazard:
-left front parking light (weak amber light just above the turn signal light)
-both rear parking lights
-all lighted buttons, e.g. TCS button, AC controls
-headlight symbol on dash
If I turn the key to ACC or ON, the the Bose system goes through a test procedure, and when it's done the LED information display is lit with every possible symbol and stays that way.
One thing to note is that I have not yet actually started the car b/c I didn't want to be in the situation where the answer is something like, "Oh man! You shouldn't have started the car!"
Any help would be much appreciated.
Cheers
Vehicle:
Symptoms:
Cheers
