Which Wideband?
Which wideband?
  • Total voters
    24
so does the prosport work with the ssafc? I was looking at them on the prosport site, and it says they are capable of datalogging and have a WIDE band for the a/f ratio. Sorry fer all the questioning on these. I'm just trying to make sure i do my research before i buy one. (boom08)
let me know who everything goes once the WB gets installed!
It may be a little bit. Everything is run but I am not currently planning on having a bung welded on the stock exhaust. I have a 3" dp w/ high flow cat and a bung for the WB that will be going in. I have to figure out what I am going to run from the cat back though. I need to post a WTB for a GHL cat back (good luck gettin one lol.) Otherwise I will have to find a good shop to fab one up for me.
I hear ya. I just bought and installed the 80mm corksport power series. It's nice me likey...(yippy)
I connected the autometer to my split second. They work really well together, the instructions tell you that the WB outputs 0-4 volts. The high and low afr output is user selectable. Low is 10 or higher and high is 15.5 or lower iirc. Plug the voltages, high and low into the SSAFC and press calculate. The readings on the gauge and the SSAFC were pretty close after that. Note: All the AUX INs on the SS are 0 min voltage and 0 max voltage, make sure you update that lol
I just got my prosport.. Too bad I'm still n Bridgeport... 9 more days until I can install it... Is it wirdthat I am getting a half chub lol
I'm starting to lean towards the autometer. It seems that anyway you go you may or may not have issues. But if there was never issues then it wouldn't be an msp!
(boom08) CHUB!!!! lol well hurry and install it so you can "get your rocks off" haha
The stock style look of the Autmeter Ultralites is what sold me!
that is a close to stock look.
To bad the Defi D-Gauges are no longer available cause that was the closest then the stewart wagners, but they don't offer a wide band.
What I like best about the prosport is that they offer the wideband in a non digital form with a needle to blend in with the other guages!!
that looks good!!!! I think your pic just sold me on one too! lol (thumb)
I also have some Dave B rings. The price is way to high for those but it really helps to match the stock gauges withe the ultralites.
