Mazda2 1.5 supercharger Project
Did you hire a hooker to blow into the engine? .5psig? mmmmm...
Is this thread for real? It would be if I wasn't so confused. What's going on here? Blower or Turbo? You say turbo...then show a picture of a supercharger and a blow off valve and intercooler...
Engine Bay Without the oil catch can
Coupler from de air box to the turbo & MAF adapter
Pipe from the air box to the turbo
Turbocharger
Pipe from the turbo to the intercooler
Header & Wastegate
Header
Intercooler
About the 0.5 psi is for the warning ligth because I have not installed the fuel controller jet and I dont want run Lean, but the wastegate is set at 6psi
About the supercharger is because the original plan was install it, but for space problem it did not was posible
Read all the thread
MRS hasn't responded yet.
Good job done and the header seems good.Now you have to install the AEM I guess in order to make it work.Good luck my friend and keep us informed.!
This weekend finaly my M2 have the Street Tuning Done at 7.5psi (0.51bar)
Next step = Dino Tuning to get the max WHP capable
Other Mods
K&N air filter
HKS Hi Power Muffler
2.25 inch (57.15 mm) exhaust pipe
but the tuner say that he recomend a 2.5 Inch exhaust pipe (63.5mm) for better torque
Hi VDS
Mi clutch has started to slip between shift on redline.
do you have info about a performance clutch or what clutch is compatible with this car?
Update
TurboXS KnockLite (shift Light & Knock Warning)
TurboXS Dual Stage Boost Controller
UltraRacing Strut Bar
HKS SSQV blowoff Ver#3
Custom Engine/torque Damper
Engine oil cooler
Carbon Fiber duct on bumper for Oil Cooler
Lightweight Crankshaft Pulley
I will post pics later
Latest posts
