bleh. **** it. just gonna fix the two 15's i have that leak and roll on them untill i fix my rh's and get new tires.
all 4 of my 17's are real bald anyway.
so im installing my rear coilovers, simple enough. do you have to replace the endlinks with longer ones? cause the certainly dont seem to be reaching
No, the bar moves. You shouldn't have any issues with it not reaching; the bar just probably won't be sitting parallel.
Ill have to get some vids. Im running 9psi, actually more like 8.8 lol.
The power band is so smooth now, my car use to fall on its face in third gear. Its like it took forever to get to the top of the gear. The manifold seems like it shorted the gear a ton. It does not take nearly as long now. Its hard to explain, it just improves the car so much and not just WOT it makes the car more drivable. it seems like it has much more power while cruising and also going up hills with the AC on.
Went to put the new pads, slotted rotors, and ss lines on yesterday. Found out I'm pretty much screwed for a while both front brake line nuts are stripped and both rear calipers are phucked!!
