My 02 has 83k on the original struts. The sway bar tab broke off the right rear, and it'll be $50+ to have some dude *try* to weld it. My struts aren't exactly shot, but they aren't 100% either. So I'm considering just replacing the struta totally, and if I'm doing it...well, we know that means upgrade time!
I'm not interested in looks. I'm not interested in lowering. I couldn't care less. I don't want super stiff. But most importantly, I want it to be perfectly damped. Not over damped, or bouncy underdamped. I want perfect. The stock setup is damn good. It's perfectly damped. It's just a bit soft.
My initial instinct is the tokico spring/strut kit. But is it well-damped? Do the spring rates match the dampers? How much stiffer than stock are they? I'm pretty sure the lowering is moderate, so that should be fine.
Any better suggestions? Cost is a factor, as well, so no coilover madness.
