What's next? Can you say quad bi-xenon retro?
Hey Matt you need to relax. I don't think that was nessesary.
As for Balls' (lol ) set up. I think you should make fiberglass housings for the fogs either than that they look good.
at least Balls' projectors dont fall out (dunno)
It happens once and apparently that's common? (screwy)
Matt, didn't mean it to sound like an f u, I was just excited that I had already done it. And yes, the fog covers didn't quite come out how I had wanted, the headlights did. It was rather overcast when I took the pictures with an old bad camera. The excecution I am rather happy with, I still have full adjustability of the headlights. It may not be the absolute best headlight retro around but that doesn't mean s*** on it. I have seen your work and it is quite good, please don't s*** on mine.
I didn't mean harshly by it, but when I spoke of the quad retro I didn't mean projector fogs, I meant using the inside projectors on the P5 headlights FOR FOGS. I just think the way you did it isn't very clean. I can appreciate the work put in though.
I'm sure you know this already, but if you don't mean anything harshly, don't call someone else's work s***.
Moving along, can't wait to see what you come up with. (wink)
That was harsh, I'll admit that.
But moving on, I decided not to do this. I'm saving up for something much better, MSP turbo setup.
Oh snap read the last words he is saying MSP Turbo Setup ,watch out lol j/k good luck with your future mods or plans on your P5
It's a stupid idea anyway, otherwise auto companies would probably do it. (stripper)
I wouldn't call it stupid. Balls did his for a reason, to have more light( the right way) and for the uniqueness. I am probably going to do the same but use Halogen projectors I have from my previous retro on my Teg when I had the USDM front on it.
Pic1
Pic2
I am going to use the P5 headlights, already have them. Too busy with my engine build right now to start on them.
Matt since you're removing the Minis, and switching to new projectors...
I wanted to ask if you had to dremel the opening for the stock H7 bulb on either the headlight base/back and/or the reflector housing in order to get the Minis to fit
thanks!
