New Member Question lowest springs???
I have looked over all the threads and cannot find anything please help!!!!
Can anyone please tell me what are the lowest springs you can buy?
I hear mixed reviews about this topic...... ie megan vs tannabe etc....and was wondering which company actually has the lowest springs?
I am looking for a true 2" drop but there are so many springs out there which one actually has a 2" drop?
Eibach Sportlines
Here's a shot of my '06 with the Eibach Sportline springs. They are about as low as you can go with factory shocks, as I'm practically on the bump stops and it just barely clears parking lot speed bumps.
Rear Camber Links
By the way. I'm running the SPC adjustable rear camber links. Otherwise the rear camber would be ridiculously negative.... around -3 degrees without them.
+1 to sportlines. they lower sedans 1.8" front/rear and hatches 2" front and rear due to the extra weight of the hatch
I've heard good things bout a few different springs including the eibachs and tein stechs. Google might be your best friend in this search. You should be able to find people talking bout springs on a few different forums if you look. The other thing to consider is if you just want to lower the car or are looking more for performance with lowering. A lot of companies offer different springs at different prices that may accomplish one or the other and then both. Then as freak mentioned you'll have to worry bout the rear camber and depending on how low whether or not to replace the oem shocks/struts which is often advised.
