*Mazda of the Month 2.0* ENTER NOW for March!
Status
Not open for further replies.
Might as well make my 1st post as a combo breaker. (outie) Troof is I wanted a 03 Pr5 and ended up with this back in 2004. Cant say I hate it having been this long now with the lil 3.
lukydog
Andrew
2004 Mazda3
Engine: (nothing fancy)
Simota Carbon SRI
Mazdaspeed3 OEM catback
Mazda3mods test pipe
TB Coolant Bypass
Timing Advance
Enigma Condensor
Big 3 0gauge upgrade
Optima Yellow Top
Suspension:
Intrax Springs
Whiteline Front End Links
Racing Beat Front Sway
Progress Rear Sway
Vibrant Tower Bar
Wheels:
18" MOMO Corse RPM Polished/Silver with Sumitomo Tires
Audio:
Pioneer Avic D3
PolkMOMO 5x7 F
Clarion 5.25 R
CDT Tweeters
Pair JL 10w3 10" Sub
POLK DB212 enclosure
JL 500/1
JL E4300
Dynamat Everywhere
Misc bits:
Mazda3mods Hood props
Mesh Front Grill
MOMO door sills
Red Stitch shift boot
LED 3rd Brake Light
Reverse Camera
Apexcone 5k 55w HID Low/Fogs
Tony
MazPro502
2002 Protege5 22v!
Mods
Audio:
Alpine Head Unit(Not in Pics)
Kicker 6x8's front door
Sony 5.25 rear door
Engine:
Aem Short Ram Intake
Painted Header Heat Sheild
Wheels:
Team Dynamics Pro Race1's
Bridgeston Potenza Tires
Hancook Ice Bears for winter
That's It...Nothing Special, Pretty Stock.
Protege's all thru this thread, gotta rep the 6 family!
The Great NY
Justin
2004 Mazda 6s - a.k.a "Punisher 6"
dont mind the blanket, lol
Engine/Drivetrain:
-Custom Twin Turbo Setup
-2 Turbonetics T3 Super 60s A/R .36
-Custom mounted Spearco Intercooler
-Raptor BOV - vta
-Custom SS 321 Piping
-Custom 3" Stainless Steel Exhaust
-MEGAN RACING M-GT Carbon Fiber Turbo Mufflers
-Vibrant Perfomance 3" Metal Cat & 3" Resonator
-NGK 6ix one step colder spark plugs gapped @ .025
-Labonte Stage 2 Water/Meth Injection Kit
-PowerMod Advanced Engine Managment System
-Granatelli Motorsports Pro Series Extreme 65,000 volt Performance Ignition Coils (only mazda 6 with them)
-Throttle Body Coolant Bypass with T-fitting delete
-Fidanza 9 lbs. Lightweight Aluminum Flywheel
-Clutchmasters FX300 Kevlar clutch
-MFactory Prototype Forged Helical LSD
-ARP Ring Gear to Differential Mounting Hardware
-Modified/Optimized EGR system modification
-AWR Lower Rear Bone Mount (95 Durometer Stiffness)
-AWR Upper Transmission Mount (88 Durometer Stiffness)
-AWR Passenger Side Head Mount (88 Durometer Stiffness)
-N2MB WOT Box with 2-step and No-lift Shift Feature
-TWM Short Throw Shifter w/bolt and hold-down modification
- Cordova Motorsports Custom Throttle Body, 60mm polished/ported/optimized w/ knife-edged throttle plate, throttle plate main shaft deleted/trimmed and remounted with countersunk screws
-Custom Lightweight Aluminum Alternator Pulley(limited run item)
-Fluidampr 10% Under-driven Crank Pulley (limited run item)
-Custom Oil Catch Can
-NRG Engine Grounding Kit
-NRG Chrome Hood Dampers(modified by me)
-custom under hood mirror inserts by www.underthehoodinc.com (1st and only mazda 6 with them)
-Rear hood weather stripping removal(for heat expelling)
-Ported Lower intake Manifold Runners
-O2simulator.com smart chip O2 simulator
-Battery Relocation to Trunk
Brakes and Suspension:
-Tein S-Tech Suspension
-R1 Concepts slotted and drilled rotors (front and rear)
-Axxis High Performance Ceramic Brake Pads
-Racing Beat Front Sway Bar
-AWR High Performance Adjustable Sway Bar Endlinks
-Motul RBF 600 Racing Brake Fluid (Dry Boiling Point 593 degrees F)
-Tanabe Front Strut Brace
-Megan Racing Lower Chassis H-Brace
-Techni-Fit Blue Stainless Steel Brake Line Kit
-Techni-Fit Blue Stainless Steel Clutch Line
Exterior:
-Autoexe GG-02 Front Bumper, 2-toned w/ black accenting(not sold in the states)
-Cyber Full Rear Bumper (2-toned w/ black accenting)
-Cyber Side Skirts
-Car-LED Black Housing LED conversion tail lights(one of the first imported sets)
-four way Brake-light Modification
-Mazdaspeed 6 Black Housing Headlights
-Black headlight eyelids
-Custom Flying “M” Emblems
-Mazda 6 Debadging
-Door Guard deletion
-Custom Stainless Polished Engine Cover and Fuse Box Insert
-Blue LED headlight marker lights
-Chrysler Pacifica Stereo Antenna
-Aftermarket Sunroof w/ wind deflector
-Hyperwhite Headlight turn signals
-Fenders Rolled
-Custom Powdercoated and Airbrushed RX-8 wheels w/ Nitto NT-05 235 40 18 TIres
-Powdercoated White Lugnuts - Inverted Style
Interior:
-Full Custom Interior and Uphostery, Done by Gillin Custom Design from the floor to the roof, nothing went untouched. www.gillincustomdesign.com custom embroidered Punisher Skull Seats, black suede headliner, black suede door peices, black suede shift boot, sunvisior delete, custom door panels, custom dash, black carpet, black rear deck lid, white seat piping, suede seat inserts, and etc
-Custom Steering Wheel Airbag
-Blue LED dome lights
-Sony CDX-M9900 cd/dvd/mp3 player head unit
-Sony CDX-757mx ten disk cd changer
-Kicker Solobaric L7 – 10” Subwoofer in custom ported box
-Kicker KX600.1 mono class D amplifier
-Blue LED door lights
-Alfa Otto Racing Reverse Glow White Gauge faces
-Custom Stainless Steel Weighted Shift Knob (2 lbs)
-Custom White Accenting throughout the interior
-Custom Center arm-rest with Flying “M”
-Lotek Tri-gauge dash pod
-AEM uego wideband O2 gauge and controller
-Megan Racing Blacked out boost/vac gauge
-Megan Racing Blacked out oil pressure gauge
-Greddy Full Auto Black Turbo Timer
-Greddy Profec B Spec-2 Electronic Boost Controller
NUMBERS:
305.29whp, 303.06wtq @ 6.5psi very conservative tune. No Dyno at 10psi yet
Future Mods :
-Clutchmasters Stage 4 Clutch
-Forged Pistons/Rods
-Ported/Polished Heads
-Blueprinted Engine
-Custom Sheet metal Intake manifold
-Direct Port Nitrous System
-Cryo Treated Transmission
-Custom Driveaxles
-Custom Traction Bars
Awards and Recognition:
2009:
-K104 Extreme Rides 2009: 1st Place Best Mazda
-Envy Frenzy 2009: 2nd Place Best Import
-Funkmaster Flex Custom Car Show Westchester 2009: 1st Place Mazda
-Orange County Choppers Custom Car, Bike & Truck Show 2009: 1st Place Mazda
-Cars 4 Cancer Car Show @ Lebanon Valley Raceway - Best Mazda
-6crew.com's 6 Of The Year 2009
-6crew.com's 6 Of The Month January 2009
-newyorktuners.com's Car Of the Month
-full article in Times Herald Record Newspaper on car
-Own Page on AWR's website, awrracing.com
-the 1st fully tuned boosted V6 mazda 6 ever
-the first V6 mazda 6 with a Forged LSD
-the only Twin Turbo Mazda 6 in the Nation, quite possibly the world
2008:
-K104 Extreme Rides 2008 at Dutchess Stadium in Fishkill, NY: 2nd place best Mazda
-OCC (Orange County Choppers) 1st Annual Car and Truck Show in Newburgh, NY: 1st Place Best Mazda
-Street Life Auto Clubs Custom Car and Truck Show in Fishkill, NY: 1st Place Best Mazda
-Envy Frenzy 2008 in Kingston, NY: 1st Place Best Mazda
-Cars4Cancer Show 2008 in Lake George, NY: 1st Place Best Mazda
-I also attended a lot of smaller benefit shows that year and placed in the top 20, 1st and 2nd place and was voted favorite car during many cruise nights that I attended.
ok NOW yall can just go home, twin turbo 6, yes plz! Luv it errytime i see it!
lol justin, your car scares me. someday i gotta see that thing in person.
yo anytime you in NY, holla, you know u gotta a homie and a ride bro. i cant wait till my motor is done bro, no more conservative tunes haha.
thanks everyone. I have a bunch of pics and etc on another forum, I'm not sure how friendly they are here about cross linking.
You can google "punisher 6 mazda". And a bunch of results should comeup for my car.
Status
