- 06 LS MS6
07 BM GT (shell has been struck from the roll)
OK only doin this cuz lots of folk are in that zone, AND to dispel any thoughts of it being harder than an oil change.
far easier than an oil change
1 lift car (in a safe manner)
2 pull shroud
3 put bucket under drain port
4 remove drain plug near control arm pivot ( get a breaker bar, a ratchet is a snug fit)
5 replace drain plug
6 pull fill plug
7 rig fill hose and funnel
8 pour in 3qt of trans juice
9 put rag under fill hole and pull fill hose (some may come out, that is correct, and normal. trannys and diffs are filled til fluid reaches the level of the fill port.
10 replace fill plug
PLEASE NOTE, you do not need to remove ANYTHING. except the shroud to do this
I borrowed AWDthis's photo for the drain port/fill port shot
the funnel rig is very high tech, don;t try this at home depot
THANK YOU
2 pull shroud
6 pull fill plug
THANK YOU
