Maxx Mazda
Contributor
- Stock P5
The JDM intake cam will be stamped "FSH9" for the exhaust cam you will need to get another intake cam and have it repinned.
s*** i bet they will, 280 is just insane.. maybe i can find them in here, by any chance do you have the part number for them so i can identify them in the yunk yard thanks..
If you can get some for lower price id buy from you!
Don't forget, the JDM cams are Mazda STOCK cams on pretty much every 323 outside of North America. That should tell you something...
I used to have them but ordered some Integral Stage 3's. (280*) They're gonna be ******* insane...
big lift to go with that big duration?
watch the big lift, especially on the exhaust side. I found the twiggies (which have some pretty frightening lift values, as befits the meanest cams you can get for the engine) will cause interference - which isn't a problem unless you're dialing in some crazy cam timing, or you lose a timing belt.... eek.
Corksport or SRM is your best bet for us canadians.
Where do you get your information? Corksport has resellers in Montreal, and their US locations will ship USPS if you request it (done it a couple of times with NO issues)
just to recap, JDM cams will be the same lift for int/ex , twiggies cams had int. bigger duration/lift then exhaust ?
If one doesn't have cam gears to dial in the right timing on higher stage cams, wouldn't it be wise to stick with JDM cams which are drop in so to speak where as the integral/twiggies require cam gears.
Also getting 1 stage higher integral for intake and 1 stage lower for exhaust side would require cam gears to better dial them in otherwise they won't be "drop in" type.
I mean which option would be better having, same type for int/ex or higher int and lower ex. ?
get on topic guys....
would you like me to split it off into a cam discussion thread?
on the off chance that someone else doesn't read through his lenthy build thread and is looking for the same? LOLwhy? Mazdaspeed2oo35 is looking to get cams in the future, he'll need info like contact info, manufacturer info etc.
