Cobb AP Discussion Thread
Did the spiking cause any fuel/boost cut, or was it just part throttle while cruising?
The issue was during part and wide-open throttle. It was a loud bang and my car fell flat on its face. I didn't feel it was safe to try to reproduce and wasn't logging it.
idk whats going on but every map i try seems the cel comes on and the to lean at idle bank 1 code keeps coming...
..i checked all the lines and there was nothing...but at idle my stft is at 0-3 but my ltft is at like 19....
idk my afr is perfect 14.3-15.0 and not much kr at all maybe 1.0 idk what should i look for? any advice? i dont have 1 step colder plugs could that be it? idk any help would be helpful thanks
Make sure your o2 sensors are still plugged in (particularly the wideband).
Those AFR's are at idle and light cruise right? Not WOT?
AFR seem good. Faulty O2 sensor or a lose connection throwing your CEL by the sounds of it. This happens only when you have the AP installed?
It's really strange that it would only happen when you flash a map. I now doubt that it is your connections. Good luck. I'm out of ideas....
what MAP to run
Not sure what map to run i got the Cobb AP today. Mods are:
Cobb SRI intake
Cobb Turbo Inlet
Forge Pistion BPV
Test Pipe
Magnaflow CBE
Mistersix- your saying start with the stage 1+ and the car don't run right then go to stage 2 or start with stage 1+ then go to the stage 1 (non +)?
Anyone notice that their car is much faster at half throttle or 75%? My car pulls like a beast on part throttle but when I go to floor the gas it doesn't seem so impressive. My guess is afr's. Im at 12.5 exaclty under part throttle boost while WOT im at 9-11.2 or so. I also notice I am hitting only 15lbs of boost. Asuming this is the cold weather.
After switching from the MS CAI to the Cobb SRI, I really like the way the car pulls. Power seems linear and more responsive than before.
Also, I did get a replacement grommet for the MS CAI, I haven't decided if I'm going to sell it or switch to it for summer duty.
For those guys running the TIHSF maps in the past, did you ever try the v103a map? I found it on mzdspd.com and was wondering if it suffered from the KR problems that were previously mentioned.
Yes, that is the map I was running that I experienced a great deal of knock with.
You guys still monitor knock? I was getting to where I was seeing 6-8 on average a few times a day. I don't even look at it anymore.
