first time i got all the bolts except two rusted round bolts (one of which was the very back bolt on the parcel shelf
So night one removed all but 2 bolts
attempt 2 saw me with a dremel (but without a cutting wheel-instead has course sanding discs) which did remove rusted bolts, but didn't have enough to cut up the rest of the shelf in teh way of the rollbar
So tonight i have an angle grinder and drill with bits needed
what roll bar is that?? The rear supports are really low on the main hoop, and the cross bar support looks like it's in a great place to bonk your lights out....
I do have one question though. i did not realize installation actually set the scoop down into the rubber, i set it just ontop and didn't use the velcrow and seems to flow more air than proper install and holds better than velcrow install too
BUT, not at highway speeds, they don't hold at all then.
I recently rebuilt the exhaust to knock down the sound levels a touch. For years, I've been knocking at the door of exceeding the local (and national) limit. This should take the car down a few dB's to an acceptable level.
Furthermore, I've been wanting to explore the realm of aerodynamics. I am therefore at the early stages of building a front air dam/splitter as well as a rear spoiler to meet the Street Prepared rule set. Preliminary construction will consist of plywood but the final product, if feasible, will be constructed of Alumilite and/or ABS.
I have assembled a microcontroller circuit as well as logging software to perform measurement/logging of [differential]pressures at various points on the aero as well as measuring suspension loading at various speeds. I have no idea as to if any of this will work, but it's an entertaining project at the very least .
