Short Throw Shift Plate for the MS6
JBR
09' & 2011 MazdaSpeed3
I'm about to bring this to market. I'd like to see what the interest is so I can decide on how many to have initially made. 40% reduction in throw and powder coated. Should be priced at $90 shipped. 15 minutes to install.
Thanks,
Jamie
so how does this benefit the ppl that already have the TMW stage SS? will this plate make the shifter throws shorter?
Thanks Jamie. Looks pretty good. In terms of adding this to a Stage 2 STS, have you tried it, and if so, what was the feedback in terms of shifting? If not, if you're looking for a tester, I would be interested.
It's too early to tell if this will be compatible with the TMW. I have not tested that combination yet. This is geared towards those that never wanted to go through the trouble of installing the TMW. When it's ready we can get together and test it.
Sounds good, consider me interested then. What's the ETA you're looking at right now?
Yeah, nice short snickety-snick throws would be awesome. I'm interested as well.
The throw is real short and for some reason much smoother feeling than the plate I have for the 3. I'm pleased with it.
Thanks,
Jamie
interesting. i'm curious on the compatibility with the TWM SS as well. depending on that result, its possible that i would be interested.
I'm not too optimistic that this combination will work but I will get it tested as soon as possible and post the results.
Thanks,
Jamie
Hey guys, what colors would you like to see this in? What colors did the MS6 come in?
Thanks,
Jamie
Hey Jamie,
I have the TWM Stage 1 short-throw shifter. You're welcome to try this product out on my car. As with the MS3 modifications, most come in blue, black, and red. If we can determine whether it works with the TWM products or not, I'll probably be on-board for a blue one.
Chris
Hey Jamie,
Chris
Chris that would be great. You're close to me too. I think the TWM Stage 1 is a more likely a possibility. We'll see.
Thanks,
Jamie
I believe the difference between their Stage1 and Stage2 kits is the Stage2 is a new shifter rod. The Stage1 is only a bracket that you mate to the top of the stock shifter rod.
Honestly, the two products shouldn't interfere unless they cause the shift to feel so short that it isn't comfortable.
I'll be available starting next Wednesday. Let me know when you want to get together.
