are you sure you saved the updated post? i believe it was 350 when i saw it b 4
can you fire it up and post interface pics?
as well as front pic;
I'm surprised you said there is no jack for gps antenna;
bump for updated price too if any.
so did you try loading SW and see if it finds satellites?Yea, it will load the GPS software with the SD card but when you look through the manual it says that the Antenna connection is optional.
if so there is everything in place but external antenna jack can be always soldered in - should not be a big problem.
can you confirm gps sw actually receives data?
well we're talking about different things here: would the sw run and second which is most important - would the sw detect hardware and receive coordinates etc.I have not tried to load the software myself but this unit has a SAMSUNG S3C2440A-40 Chip set with the following features:
*GPS Store space Main frequency: 400MHZ
*Memory: 64MB
*Store space: 64MB (can external to 4GB)
*Navigation software store: SD card
*Operation system: WINCE5.0 CORE can read 3D map
Any GPS software that works with Windows CE 5.0 will work with this radio.
I bet IGO for instance would be running fine but would it function? that's the question.
if there is gps hardware in this unit then you may try selling it for what you ask (or even more) but if not it may not be that interesting deal for the price (for roughly hundred and fifty more you get new unit with gps and better screen resolution, better sw etc);
I understand you took it off already but I think any potential buyer would like to know the answer to above questions. just my two cents here
sw can run but if there is no gps hardware you will have no data.I thought I was answering your question but I will try to clarify. Yes I think the software can be loaded and yes I think it will run. When I go to the GPS option on the home screen it tells me that the SD card isn't installed. The only thing that this unit is missing is a connection for an external GPS antenna.
The only thing I am uncertain about is if you need an external antenna for the software to work correctly. What I do know is that an External GPS antenna connection was an option that is not included with the radio I am selling.
Did that answer it?
I honestly don't think someone would include/exclude just antenna when selling such units. It does not make much sense to me. But China is country of contrasts lol so everything possible )
if you run gps sw and it reads you location then it should not be a big deal to wire external antenna. But answer is not clear if sw would receive data or not. And this is the key question.
cools! then this is great price for unit like this. GL with sale and another free bump )The GPS hardware is installed. The chipset is referenced quite a few times in the spec of this unit and in the users manual. The only GPS hardware that was marked as optional is the external antenna port.
so really all you need is a gps antenna and your good to go with gps or do you need a sevice or anything? im super tempted to buy this thing.
