FS: AXIS' Rebuild Sale - Reworked K04, PG Manifold, Turbo Inlet!
Status
Not open for further replies.
for the turbo inlet, does the barb fitting for the vacuum line fit the stock line? Will you include a coupler for where it connects to the turbo? I have a MS CAI so I assume the top portion will all hook right up? If it bolts right up I will take it.
bolts right up to ms cai..and yes i will include the reducer coupler from the inlet to the turbo...i don't know about that barb...didn't need to hook it up
its been awhile since I physically looked down there, but I believe there is some sort of vacuum line that connects there on the stock inlet. Where did you run your line to? If all else fails, just tell me the barb size and I will find out if thats the same as stock.
i honestly have no idea what the barb size is...the previous owner of this TIP had that barb capped off so it was not in use at all..its just there
can you use the reworked turbo with the stock turbo manifold??? does it hold more boost? is it good for more hp?? and wats the hp gain like
^ya its fine to use the stock mani. It should be able to hold more boost without problems which with the right tuning means more power. As a bolt on with no tune the gain will be noticeable but nothing huge.
INLET IS SOLD!
INLET IS SOLD!
I will send u the reducer coupling for the TIP to the K04 also
wow thanks for the info thats sweet..i herd it helps with the smoking issue too...and no tune wow..and it says 30hp nice u liked it
dont tell me u went gt 30 thats y u sold it
and i want it but im having big money probs rite now...400carpayment due the 4th jus paid my insurance and 400$ speeding ticket due the 10th and then carless driving due the 18th..ugh!!!!!!!!!!!
dang u were just getting my hopes up (bang)
and yes i am getting a GT3076R from Ken @ PG
Status
