hopeing to get this done today, but i dont have a grinder, so if the bolts dont give, im screwed for the day =( coated it with wd40 so hopefully ill be able to pop these in. i also have my awr bushings which have sat on the desk for 6 months..
well. i already hosed the nut on one side with my wrench, so ill be grinding them off anyway.
if your buying springs and struts you might as well just fork out a little more and get coilovers.
Just struts as i already have the springs and I dont think I want coil overs because I can't go any lower as it is... I dont think ill clear the speed bumps if I go much lower. Right now it looks like I clear about 1/4 inch with the front bumper.... They call them speed bumps but they are a little more then bumps where i live.
yeah, it kinda suck to do, but man was it worth it!!!! Its Quiet and the front end just seems soooo much tighter.. I like
how bad were the old bushings when you took them out? when i did the rears they were completely trashed, but i was disappointed that the front one was not as bad. a little smashed and misshapen, but not crumbling or cracked. this is with about 50k on them...
i just went with moog stablilizer links that were almost 3 times as thick as the factory links and i only paid about 50 bucks
thinking about putting the pro5 spindle in the car because the wheel bearing in my driver front is irritating an vibrating the whole car. need to go rent a 32mm socket though. and i wish i knew which way my new camber bolts need to putting to adjust my camber.
plus i will probably be meeting a local msp owner. it will be the first spicy i have seen in person.
the camber bolts should rotate to adjust the camber, like a cam lobe. if the lobe points out, that will be positive, up or down is neutral, in is negative. (I think... if you put them in and rotate them you should be able to tell.)
well im guessing its leaning in. the bottom is sticking out farther than the top of the tires.
and some are leaning more than others
