7mileshome
- Mazdaspeed3
Contact darrell cox racing about the rod capabilites they just did testing recently. And your boy is getting hooked up with that speed6. My injector seal failed on the first cylinder causing an intake valve to stick shut blew my pcv valve apart big oily mess anyways it ran me 2300 to remove the block tear it down put it back together then throw it back in then 2050 for machine shop work. 600 in gaskets seals bearing rings etc all this and no forged. Maybe i got ****** but this isn't as simple as it seems. If you can get it done cheap go for it man i wish i coulda but i gotta sell all 3 of my testicles to afford this s*** hahaha
It sounds like you went with the first option after something bad happened. This guy is prepping for a motor build, he can shop around. This build can be done for less than 2500, if you are in NC, I can tell you where to go.
