p5 headlight in msp?
03.5 YLW MSP
I have found several pictures and of MSP's with p5 headlights however I am unable to locate a how-to for the swap. To make a long story short I need new headlights. I'm thinking of swaping in the p5 headlights on my MSP however I do not know how to go about the electrical side of the installation. Does anyonw here know?
Edit: Just for those curious why the p5 head lights. I want to go with blacked otu p5 headlights and install the DDE kit! I know im a ricer. lol
http://www.xenonexpert.com/ddekits.html
He sent me this...
xDJ DUBx said:
It's not that hard, basically you're just getting the connector for the car and the connector for the high beam then joining the ends of the wires together, along with the hid wires, to make your own plug-n-play setup for the headlight swap.
You need #5005, female 9005 connector
You need #5028, male H4 connector a.k.a. H4 reverse harness
You can get both sets at suvlights.com for 50 bucks or you can save some change and get the H4 harness from ebay. They don't really have any 9005 connectors on ebay, just 9006 which is very similar but won't work.
Then, after you have the harness's, you use the bottom half of this wiring diagram.
If you want your lows to stay on with the highs, you don't use the middle top wire on the H4 harness. One is the hot which you wire the hot from the hid to and the hot from the high beam. The last wire is the ground for the high beam so you wire the high beam ground to this last wire. Then all your left with is the ground for the hid kit low beams, you just ground it to the car. Put it all together nicely and boom, finished.
Can someone help explain this to me...
Ok so you need two of the below(one for each side)
#5005, female 9005 connector's
http://www.suvlights.com/images/Different_sockets_01.jpg
#5028, male H4 connector a.k.a. H4 reverse harness's
http://www.suvlights.com/images/male headlight sockets_lg.bmp
What about the other headlight? I do not know if the 9005 connector is for the high or lows on the p5.
The part #5028(h4 connecter) connect plugs into the stock headlight harness. From their you take the power source off of the h4 connector and use it as a common power for the part #5005(9005 connector) and whatever the other headlight connector is... Im lost. lol
xDJ DUBx said:
Its hard to describe without pics. lol.
Yeah, you need two of both, one 9005 per headlight and one H4 reverse per side. The 9005 is to connect into the high beam bulbs.
Here, I drew this up real quick to help. Should make sense now. lol.
http://i477.photobucket.com/albums/rr131/xDJ_DUBx/Personal%20Life/bad.jpg
Remember, H4 is for the car, 9005 is for the high beams and the hid kit has a regular hot wire and ground wire to hook up some place.
Cheap p5 headlights!
http://cgi.ebay.com/ebaymotors/MAZD...ryZ33710QQihZ017QQitemZ270370451898QQtcZphoto
i wanna do this now. it would be awesome
somebody should make a how-to im not the greatest at custom wiring.
Its a little scattered and confusing, if you cleaned it up, it would make a great how-to
I didn't take any pics but that bad paint drawing I did is all you need to know, real pics aren't really gonna tell you much more.
dj dub do you have any strait from the front pics of your car? i would like to see the headlights like that if you could.
thank u dj dub. ur car is gorgous. off topic: what kinda fogs are those? ive been thinking about putting some down there like that. and also how did u attach them?
Thanks (2thumbs)
They're "Autopia" Fogs from ebay, if you search up protege fog lights, they're the best quality ones that have halos. The mounting bracket that is included is perfect for drilling into the underside of the crash bar to mount them.
