GarageClearing Sale......
Status
Not open for further replies.
25FConv
Mazda Protege
Buy Some Good Stuff Here.
Trying to clear up some space at my shop and get rid of some old parts, some new parts, and some parts I just don't need with my setup. So lets Get started. Nothing includes shipping as of yet. Prices are a bit Negotiable.
Paypal is: gmramdhani13@yahoo.com
I work 2 Full-Time Jobs. I will honor Dibs......but Understand some items may take some time for me to ship out. Tracking Numbers and Insurance can be provided upon request.
Stock Cam Gears(2 Sets)- $35 a set. 1 set(SOLD Pending Payment)
440 Injectors- $115. (SOLD to _MSprotegy)
626 Valve Cover- $75
MSP/P5 Bumper Reinforcement- $160
AWR Strut Mount Camber Plates(Discontinued)Looking for what I paid-$275(SOLD to 03.5MSP)
More Stuff......
Pass. MotorMount- $35 (SOLD to Demo)
Pass. MotorMount Inserts- $25 (SOLD Locally)
CF Mirror Covers- $75 (SOLD to Discospeed)
Cup Holder- $40 (SOLD to big Lou)
Dave B Rings- $60 (SOLD to xJAZx)
And More Stuff.........
Fog Light Brackets 4 P5/ '03 MSP- $50
Gauge Cluster Painted Dials Silver - $100 (SOLD to Mazdspeed)
MSP GT25 Turbo 20K Miles, No Shaft Play-$350 *EDIT, I made a mistake this turbo has 30K on it. Thank you to TWISFM for pointing out my error.(SOLD Pending Payment)
Reserved#3
...maybe........second thought gonna need more spots.....
Stock Wastegate Actuator(NoAdjusterScrew)7Psi- $40(SOLD Pending Payment)
K-Sport Koilovers( I think the rear 2 are blown, but you can get a replacement from K-Sport for about $125each)- $325( SOLD)
Nology Hotwires(Red)- $100 (SOLD to big Lou)
Nology Hotwires(Orange)- $100
Stock Shift Boot- $25
possibly #4 too.
SandBlasted 2.0L Valve Cover- $75 (SOLD to Metallic36)
Bank 1 Oxygen Sensor- $70.......no sure if its for the 2.0L
N2MB WOTBOX& 2Step Launch Control BNIB- $170
Stock Bypass Valve- $25(SOLD)
Jeez lets me load......you will like some of the stuff...i promise.
SLS WaterNeck- $25(SOLD to racerx43269)
Stock Head(No Cams)- $100 (SOLD to br289165)
Stock Cams- $30(SOLD Pending Payment)
Stock ES Springs(4)- $45 12K Miles
Stock Struts ES (4)- $100 12K miles (SOLD)
I will answer these PMs right after I finish posting up the pics........
Stock Rear MM- $45(SOLD Locally)
Stock Trailing Arms- $20
Stock Tranny Mount- $55
OEM Throwout Bearing- $30(SOLD Pending Payment)
OE Pilot Bearing- $15(SOLD Pending Payment)
y mas......
TurboXS ByPass Valve- $80
Finally, One of the rarest Ignition Setups for the FS-DE:
BLUE-FIRE DUAL CHANNEL IGNITION AMPLIFIER w/ 4.6L Accel Coil-Pack & Grey Nology Wires
Looking for $400
Here is Some info on it.
The Blue-Fire Dual Channel Ignition Amplifier from Perfect Power is a powerful, microprocessor controlled ignition amplifier with an updated exterior.
The continuous current rating is an amazing 30 amps per channel at 25 deg C. The Blue-Fire Dual Channel Ignition Amplifier is specifically designed to cater for the extreme demands by high current coils in performance applications.
For the ultimate in protection, the Blue-Fire comes totally encapsulated, preventing ingress of water spray, oil and the like.
Blue-Fire
The Blue-Fire's improved housing includes 6 pre-cut grooves allowing for ease of mounting. Its lightweight aluminium body also serves as a heat sink to dissipate heat losses during peak demands.
The power connections consist of solid, plated brass terminals, using lugs with 4 mm screws to achieve quality contacts. The supplied crimp lugs make termination an easy task. The Blue-Fire is designed to be installed in the engine bay, keeping power cable length to a minimum.
FEATURES OF THE BLUE-FIRE
* Lightweight
* Small size
* Easy to mount
* Extremely rugged
* Processor controlled
* 2 channels in one unit
* Over current protection
* Reverse polarity protection
* Built-in temperature cut-out
* Bright LED’s to monitor functions
* In- and outputs can be paralleled to double power
* Can be used with 24 V battery systems
* Ideal for high revving or high boost turbo/compressor engines
SPECIFICATIONS OF THE BLUE-FIRE
Supply voltage range: 9 to 28 VDC
Current demand from battery: typically below 20 mA
Input voltage to trigger: above 1.0 V to 1.5 V (above 5 V recommended)
Input /output relationship: A positive input voltage will turn the power switch on.
Max switching current: 30 amps continuous per channel at 25 deg C.
. 20 amps continuous per channel at 80 deg C.
Protection:
Supply voltage polarity reversal: YES
Output terminal polarity reversal: YES
Max output current: Self limiting, temperature dependant.
Overload: Yes, magnitude and time depending will eventually bring up over temperature.
Short circuit protection: Yes, pulse by pulse monitoring with instant shutdown.
Operating temperature range: above 80 deg C , cutout with auto-reset function once temperature has dropped to below 80 deg C.
Indications:
Input signal present: Yes, one green LED per channel
Output overloaded / shorted: Yes, one red LED per channel
Over temperature: Yes, both red LED’s flashing
System fault: Yes, both red LED’s on continuously.
Status
