I painted my Stockers.
I don't have pics at the moment but they turned out pretty awesome.
My method:
Things you will need:
2 different grits of sandpaper.
4 cans of spray primer.
8 cans of the color of paint you plan on using. (Note: I used paint made for wheels, but basically any automotive paint that will bond to primer will work.)
4 cans spray clear coat
1 Hot day with lots of sun and low humidity. =P
1. Take your tire off your wheel. ( If you can't do this or it's too much trouble, just get some newspaper or note cards and some tape, and cover em, but not until after you are done with step 6)
2. Wash and dry wheels.
3. Sand wheels down using 100-150 grit sandpaper. (Take your time! Keep it even. This step took me and my friend about 3 hours.
4. Wash and dry wheels again.
5. Sand wheels again using finer sandpaper like 300 - 400 grit.
6. Wash and dry wheels again.
-If you are covering your tires with paper, this is the time-
7. Spray 1 Can of primer per wheel. Even coats. Take your time.
8. Allow primer to dry. (About 15 mins per coat depending on how thick you go.)
9. Use paint (2 cans per wheel). Even coats. Allow to dry. Yada Yada Yada.
10. Allow paint to dry.
11. Spray clear coat. (1 can per wheel)
12. Allow wheels to dry and cure. The longer you let them dry, the better chance they will have to not fade or whatever.
That's basically it. It is a long process. Me and my friend started at 9 o clock at night, stopped at 4 in the morning, woke up at noon, and went until about 5 that night.
Don't forget! Have PATIENCE!
Hope this helped!
IF you want pics, lemme know and ill try to take some.
