Rockin03mp5
- '13 Mazda3 / '13 Edge / Your Mom
1st of all my Mi. neighbor, there are 2 types of engine braking when referring to semi trucks. One does not use a jake brake, the engine braking effect is caused by simple downshifting, the second effect is caused by the use of an optional Jacobs brake which shuts down, I believe 2 of the common 6 cylinders and causes a much more drastic slowdown in braking, but not all trucks have jake brakes. It is usually illegal in populated communities to use jake brakes, due to the excessive exhaust popping noise from the added compression effect of the engine brake.Regular engine braking does not create any more noise than upshifting and is therefore not illegal. I know, because I've been driving 18 wheel 10 speeds with and without Jake brakes for a long time. Even though we weren't really mentioning auto P5's, the auto's can engine brake just the same. May I ask how old you are?
i know about the jake brakes. you were saying it is illegal to coast... which seems funny to me. (is it a MI thing? cause i will ask msp next time i see them)
I know my auto can engine brake, but i do have the manumatic, which makes it easier to. regular autos would have tougher times. i think if you avoid hard braking, you will help your brakes out more than just always trying to engine brake. technically though, to avoid hard braking, you will have to engine brake, or at least get off of the gas, earlier.
and what does my age have to do with anything?
