Post The Best Pictures of Your Mazda
The damn cam moved :(
04/06/07
Back on topic!!!
Don't think I've posted this one here. Pic from last March, taken by fellow member and camera wizard, Gujustud.
Dude...you are giving me inspiration for the in the garage.
Anymore side shots/rolling shots?
Gangstaness Tigermack! :tup:
Nothing new at the moment bro. Im waiting for some s*** thats being shipped. Go work on the MX. If you can work on a Protege 5 you can work on a MX. The P5 chassis is based off of the MX6 chassis (im sure you knew that though)...lol.
Where did you get that information at? I have never heard of that before.
The mx6/626 was produced before the 99-03? Protege. The wheel bases are identical 102.8 inches. The suspension setups are similar only difference is the mounting points (sway bar/lateral arms/trailing arms. You can put protege coilovers on an MX6 and Protege brakes will bolt right up. IIRC...subframe too.
The mx6/626 was produced before the protege. The wheel bases are identical 102.8 inches. the suspension setups are similar only difference is the mounting point (sway bar/lateral arms. I can put protege coilovers on an mx6 and protege brakes will bolt right up.
ok but I want o read material on it! I think it would be an interesting read.... I can put mazda 6 breaks (msp have 6 breaks from the factory) on my car but that doesnt mean that they share the same platform....
Chassis codes probably arent the same. I have no idea what the Chassis code for a Protege is. Im not saying the platform is the same but the Protege platform is a redesigned version on the MX6 GE chassis. It is what it is....the wheelbase is 102.8 inches on both cars....
So... you have no material that I can read on this then...
