OK, Forge installed, blue spring no shim.
Took about 15 minutes, had to wrestle with the big pipe to get it lined up right, and I'm NOT happy about the way it is in there. Is the Forge rotateable about the mount/flange? I know the top part with the thin nipple is, but I would REALLY like to rotate the bigger pipe about 15* to make it a straighter shot into the return pipe.
ALSO....HIGHLY HIGHLY recommend replaceing the crap compression clip doodads with screw type clamps. The one for the small nipple only holds the tube on there because Forge saw fit to flange the nipple, it slid all over the place with no pressure and probably rubs when the pressure fluxes.
Now, my spino-dyno is damaged, and weapons grade anti-inflammatories have reduced the sensitivity of the instruments, but I would not be shocked to see increased power across the band, with a possible increase in peak. Why do I say this?
In the week I had the CAI on with the stock BPV, the sounds from the intake sounded different then they do now. For starters, you could hear the suction start to build at about 2K, depending on gear, load, throttle pressure, ambient noise (my stereo has only two settings, off and f*ckin' loud) etc. But even my wife said that the sound changed pitch and frequency at about 2750. Now, it stays the some frequency, just getting louder as the turbo spools, with an undertone of compressor whine starting at about 3500. The mid-range hiccup is also gone, only noticable after sitting at a light for a while, meaning its the computer retarding spark due to heatsoak (the penny jar is refilling for a FMIC). But otherwise, even at part throttle, the acceleration is a bit more aggressive.
Now, the sound. I dont see what the big deal is. Sure, there is a metallic quality to the release sound, but its not a ping, or swords clashing, or Mario ganking a coin. Its more of a metallic whistle, like a metal ball in a plastic whistle. And its over in a heartbeat. Best off all, if you listen carefully, you can hear the released air chuff back into the system right before the main release, its almost like a three part sound, huff-WHOOSH-tinkSHHH.
All in all, I couldnt be happier once I replace the crap-o-rama clamps with some real ones, and get the IC cover shaved down a little so it doesnt chip and shave itself to death on the CAI return pipe.
EDIT/PS: OI! Whats the diameter of those hoses so when I go to Autozone tomorrow I get the right size the FIRST time?
