Not really sure what to call it, so we'll go with CAI wheel well shield.
I was a little leary of driving in the rain with the MS CAI because of how open it is to the driver side wheel well and the stories I've heard about hydrolocking. So I set out to find some way of hindering water exposure without cutting down the air flow too much. My first thought was to use some 8-1/2"x11" sheets of 3M scrub pads, but I couldn't find anything bigger than 3"x5". After several days of looking I was at Home Depot getting some stuff for the house and saw some rolls of roof ridge vent material. It's not as dense as the 3M scrub pads, but testing with a hose nozzle showed that it significantly decreases the velocity of water exiting the other side (60 PSI water spray in the front, drizzle out the back)...which is what I was after.
Below are some pics of the install. I'll probably end up using this same method (but maybe with different fasteners) whenever I get around to doing the fog light cut-out.
Parts and tools I used:
10-1/2" X 11" piece of Cobra ridge roof vent material from Home Depot
1/8" X 1" zinc washers (x8)
1/2" X 5/32" (12mm X 4mm) rivets (x4)
Phillips screwdriver
Riveter
Before:
Backside with fasteners:
After:
With this and the hydroshield I have on order I'll be a lot more comfortable driving in wet Oregon weather.
BTW, I saw somebody say in another thread that their MS CAI came with a hydroshield, but mine didn't. Did I get jipped or does the new(er) MS CAI not come with one?
Riveter
Before:
After:
