I had some clunking in front but that was because i forget to tighten an important bolt. Maybe i am a bit out there, but even after a shop does work that is above me i go back and check hardware after some driving miles. you should have no new noises in my opinion though. Unless there was something missed. People say you do not need a wheel realignment after install of Cobb springs. Have your shop throw it up on the lift again. Boy that front end is low with lip. cool
Yeah I gave it a few days thought (hoped) maybe it was just the springs settling but I still got the noise. Called them they are going to look at it friday (I work 3 12 hour midnights this week). I would descibe the noise as a clunk slightly higher pitched like under tension. It occurs over bumps, worse at slower speeds.Noise only seems to be in the front. I got alligment at same time as install steering is straight as an arrow and I got no noises driving in a circles in a parking lot. There is no play in steering wheel and I couldnt imagine it is the struts as it began basically as soon as I left (however they were closing as I left). The ride isnt bad but the noise is deff. noticeable if there was no noise I would think it is normal. I think I will call cobb too to see what they say or maybe Ill wait to see what this place says?(boom02)
