15mm eibach wheel spacers. help?
are there any risks with running spacers?
Yes.
Your wheel bearings will probably wear a bit faster from the increased stress on the hubs, and your car's handling dynamics will be a bit upset due to the increased scrub radius in the front and the increased length in the moment arm component of the rear suspension's passive rear steer.
after thinkin about if im gonna hopefully try and send these back or sell them and if i order new ones im gonna go with 10mm and make sure im sent the ones that im suppose to get.
I hope you get it the way you want it sorry bout your troubles.
I had 1/4 inch spacers and they gave some stance, I just sold those on here the other day for $30 shipped. I have the 25mm spacers which are a tad wide but fit flush and look bitchin. The EBAY auction I mentioned earlier, if you look at the sellers items, they also sell 15mm and 20mm spacers with the studs built in.
builthatch's ride with 15mm spacers looks great THO imo i think it can go wider just for looks wise, me and madvillain have the 25mm which looks flush as you can get basically, tho 240ka is getting the 20mm which I would say are probably a good bet, not as flush as 25mm but not as inward as the 15mm.
I did have to roll my rears with the 25mm, but I do have springs that drop the car 1.4 inches in the front and 1.4 inches in the back. If you aren't dropped that low I woulds ay the 25mm should be flush and look best as your suspension when it compresses might cbend inward enough to avoid hitting the fender
