235/40's on 18x8 38 offset will it work?
ZOOMZOOMDUDE
09 MS3 Sport
Well the tittle says it all.. I came across an amazing deal on some Falken Azeni RT-615. They are 235-40-18 and my wheels are 18x8 with a 38 offset. Im running the stock tires at the moment. From the looks of it, it looks like it will work. I think maybe some slight fender rolling may be needed. Does anyone have some low offset wheels with that size tire?
youll need to roll them for sure, im running a 225/40 and i had to do some serious rear rolling
you will most likely rub on bumps..i have 18x8.5 38mm with a 225/40 and after i rolled them they look perfect. with the extra width you will probably rub. i'm local so if you wanna take a look pm me, i can also show you a good place to get them rolled for cheap
