Mazdaspeed2oo35
600whp - 600wtq at 30 PSI
Don't bother with the "wide body" fenders. It looks UBER dumb. The brakes though are a must. I'm running 13.1" directionally vented rotors and six piston calipers (i think you've seen them?) it's a one off Wilwood setup for the protege. The 13" rotors on the rear I found to be too much. There's not nearly enough weight in the back to make them even close to effective, even with EBFD... Some nice rotors and grippy pads out back are more than sufficient, ubnless you add another 8-900 lbs over the back wheels!![]()
I'am not doing a wide body kit, these people does something to the fenders that you can use wider wheels and tires. you can't barely see it from outside..
