absolutamente
- 2007 Mazdaspeed3
I just finished installing the corksport race pipe and the exhaust is leaking from the doughnut. I got back under, noticed the race pipe flange and exhaust flange were not paralled and that the exhaust was leaking from the top of the pipe between the flange and doughnut. So, I loosened up the bolts and readjusted everything as best as I could, tighened it back up to about 2mm between the springs, started it up and it still leaks (but not as bad). Any ideas? The install was an absolute b**** and I am a little frusterated at this point. One of the hangers on the pipe would not fit into the rubber support no matter how hard I tried and I had to remove the cross brace to get the pipe out and in. I did notice that the exhaust side race pipe flange is not perpendicular to the pipe, is it supposed to be that way or is mine defective? I was also wondering if the doughnut would just settle in over time and the leak would go away?
