i cant get it to boost over 15 in third, then in 4th i get about 16psi, 5th and 6th i get 19psi i just dont understand it, how do i get 18 in 3rd ?
unless you bypass the ECU control of the wastegate, a boost controller will not work properly.
i have a map clamp i just havent had time to install it so when i do it will bypass the ecu controlled WGA ?
You say that because of the effects of the stock ECU interfering with everything?boost "control" on this car is kind of a joke. Just something I've discovered over the months.
he says this because he had problems with his ms3 via his ap.
controlling the boost is fine. like said above, cant expect to much from a mbc. standback or the ap is all you can really do to fix it for real.
i know. just saying a few options. if you got more your more than welcome to share them. im sure poeple would love to know all the options on the table right in front of them instead of searching.There are more options that just those two.
http://siteground207.com/~protegeg/index.php?cPath=160_259
