Outlawstar98
- 2003 MazdaSpeed Protege / 2013 BRZ
I just finished installing my rear brake rotors/pads.... and GOD that was annoying haha
We've got a good bunch here (with a few exceptions I'm sure)
Its a speed limiter at 135...at least on my msp it was I don't have the balls to try it on my g/f's p5. Engine just backed of at 135ish or so. No cars on the road except the caravan of proteges behind me
I thought that msps top out at 155?? I hit 130 a couple years agoit was nice
Is anyone here running Tokico Illuminas and Tokico springs?
Yeah I got the Illuminas but not the springs. I am cheap. I want some aftermarket springs. However, I wasn't going to go with Tokico though. I honestly had no clue what I was going to go with.
The sleeves are fine as long as you don't try to dump the car on the ground and not leave enough shock shaft for the correct amount of suspension compression. The reason people find sleeves to be bouncy is because they order the wrong spring rates which with the ground controls you can change...also numb nuts like to try to use stock shocks with sleeves where as he has illuminas so it can handle higher rates.
