LTFT
My LTFT's are usually about the following:
Idle = -1 to -3
Low RPM/low load = -1 to -3
Partial throttle = 0
WOT = 0
Those look great to me. About what I see on my stock MS3 (okay, I do have an AWR 88d rear mount... but that has NOTHING to do with boost).
Actual pedal position vs. Absolute throttle position sensor
Another thing I noticed is that I am at WOT (actual pedal position at 100%) while the Absolute throttle position sensor is registering 35% to 55%?
I have read that the ECU will adjust the "drive by wire" throttle. But doesn't this seem a bit much??
This is normal. The ECU will allow the throttle to be fully or near fully open upon initial boost generation, but after that... it's rarely open much more than halfway. There's a lot of discussion about this.
The problem is that there are not a lot of stock dashhawk logs out there to compare to. Most people seem to start logging after they have started modding. I got the DashHawk first on this car to understand how the ecu is working before I started modding, that way I can understand the effect of each mod.
Ask... and ye shall receive. I went out and did some boosted runs to get some logs. As I said, my car is stock (except the mount). Here are some logs -- I am HAPPY to take screenshots at higher res, but figured I would keep the res down -- hopefully the logs are still legible.
4th Gear:
5th Gear #1:
5th Gear #2:
I realize that the higher gears don't go into higher RPM... but you'll understand I would prefer NOT to post logs showing my RPM and what gear, thereby admitting to insane speeds. I may... I may not have some logs with higher RPM runs and those logs, which may or may not exist, might show the boost continues to go down.
Also, realize that the TPS and WG DC are graphed against the same scale -- so, to get the reading for WG DC, look at the light purple numbers.
So, analysis? The fourth gear run shows an initial spike of ~16 PSIg and then it quickly falls off and by 4k RPM boost is below 13 PSIg. By ~4500 RPM, boost is ~12 PSIg and continue to fall.
First 5th gear run initially spikes to ~17 PSIg then quickly tapers and holds for just a moment at ~15.6 PSIg. After 3200 RPM the boost drops to ~13-14 PSIg range. The second 5th gear run is nearly identical.
Finally, 6th gear run initially looks great... however, notice I start the run at 2500RPM (whereas the rest started at 3000RPM) which is normally more load than I like to put on the engine... but I do this for science. At such a low RPM, the boost is maintained about 15.6 PSIg until about 3300RPM and then its downhill from there.
I would think... that if I had a significant boost leak, and the ECU were targeting a higher boost, the WG DC would be bouncing around and the boost would be bouncing around at the ECU tries to maintain that boost (e.g. 15.6 PSIg)
