stock injectors psi limit
and what are you planning to do? drop in a larger injector, use the stock ecu with no tuning device, and lower the fuel pressure if its too rich?
where is this adapter you speak of?
i rather put a fpr on the stock location...
i am using the mbxmotorsports adapter. i have seen one other brand posted up recently.
you will not find an aftermarket fpr that will fit the stock fuel rail. also, the aftermarket fpr's are usually larger than the stock unit, meaning it would be difficult fitting it in the stock location.
I honestly don't remember who makes it.. I don't see a reason for it if u get any ems! Pointless money spent
when you change the injecteur..for setting....you change all the value in the ss afc or only one value you in the parameter...
From what i understand, some other tuning device could be hooked up to the FPR solenoid and you could select the CC of injector you're using to reduce the fuel pressure so all the values on the map would still run the car the same as before.
BUT! The SS AFC or FTC does not have this ability and you must reduce every value on the map to get the same fuel ratios with bigger injectors.
If you want you can get a fuel pressure regulator and manually control the fuel pressure yourself. But it's propbably easier just to select all in the SS software and decrease by percentage.
