- 92 & 16 Meyatas
fuse # 10 (INJ or FIP), 30 amp fuse for the ecu...car was running fine, off to get gas, fill up, turn the car back on off i go...about 1/2 mile away while taking a right hand turn i loose power...everything dies. pull over, try cranking it a few times no go...check fuses and sure enough the above fuse is blown, pull out another 30 amp fues pop it in, turn it over, it blows? any ideas, thoughts?? i'm search the forum as well...i'[m stumped? thanks!
