VAC/Boost numbers
MicaSp33d
Mazda, Mazdaspeed3, 2008
lately my VAC at idle is around 17s ... after a few minutes of driving it then reaches 20s ... and sometimes goes back to 17s
do i have a vaccum leak and possible boost leak?
I noticed when I'm idling with the AC on or turn the wheel it jumps to -17, so its probably normal
i disagree, i think you're fine. i see -17 up to -22 sometimes and i think it has more to do with cold starts, temperature otherwise, and other s***..idk really, but i don't have any leaks
i second philly i see about 19-20~ at idle and like 17 with ac on. i think your fine as well(guitar)
assuming your a/c is off.....when you first start the car it will be something like -17 and once the engine runs for a second or warms up it should be sitting around -20 to -21 given your at sea level no elevation taken into account. so if your vac is -17 sometimes while the engine is completely warm you have some kind of leak
I agree with both of them. If I'm at idle with the A/C on, I'll get around -17. If it's off, then anywhere between -20 and -22.
It all depends on when you look at your boost gauge. When I first turn on my car when it has been sitting for a long time the car idles at 2,000 rpm...then slowly starts to drop. When it idles high after sitting for a long time my boost gauge will show around -17 vac. But after it starts to warm up and the RPM idle drops to the normal ~800 RPM then it reads 20-21 vac.
If you car is warm...and sitting still idling..it should not be at 17. I'll see 19-18ish vac when I'm idling with the A/C going.
well numbers look normal now ... i get 18-19s on cold start (well its not cold hear in cali) and 20 when warm. even 18-19s and sometimes 20 with the a/c on now.
it could have been the weather affecting the tubes. I will just keep looking at the boost gauge just to make sure .. but all seems fine right now. But im not gonna rule out the possibility of boost leak.
