I have checked the fuse (the yellow 20 amp, labeled H/CLN) that was broken... I am just wondering where can I buy the fuse replacement besides the mazda company? Is it possible if I can order just 1 fuse for that part? Thanks!
go to any Walmart, K-Mart,, Krogers, Meijers, Gas Station, autoparts store and prolly some local lemonade stands at the side of the road and you can pick up a pack of replacement fuses for like $2-3? If you check the panel you may find a spare one listed on the fuse block you can use until you buy a replacement.
Have you been plugging anything into it? I blew that fuse 3 times and finally figured out that my non-oem cell charger was doing it. If you blow it more than once and are using a non-oem charger, I would suggested getting an oem one.
At least once I removed and then reinserted it, once I twisted it around (it may have lost contacts for a minute) and once I believe it just did it while it was plugged in.
