no front camber plates
Listers
08.5 MS3
since BC coilovers no longer come with front camber plates, how does the front camber get adjusted? will i get uneven wear on the front tires? how necessary is the front camber correction?
wtf r u talking about??? just got my bc coilover with front camber plates today!!!
well i guess my question still stands because im assuming mine are the ones w/o the camber plates
I was only aware of the 3" hole saw trick to allow plates and adjustment for the BC. I just went for upgraded springs. It looks like the rear is adjustable with stock , not sure how much . I hope this works out for you. The front camber setting can make a big difference in steering and such. Maybe you will not be able to drop it too far without correcting the too negative from running super low. Good luck!
