FS: COMPLETE Synapse BOV Kit
Status
Not open for further replies.
pidass15
I'm selling my Synapse BOV with all the tubing, T-fittings, and recirculation tube all together as a kit.
What comes with it:
Synapse BOV
Mazdaspeed Flange
O-ring
All hoses and fittings to hook it up to the wastegate actuator and split the stock vacuum source
Already cut recirculation tube (this way you don't have to cut yours up, this is a $30 OEM tube from Tiffany)
The only thing you will need:
Allen screws to securely attach valve to the flange (Synapse supplies some really wimpy allen screws, so you should really get heavy duty ones anyways). Set screw size is M3 so you can use M3 x 3.5 or M3 x 4
I've had the valve on the entire time without the set screws and it's never blown off or anything so you should do this just for peace of mind.
Synapse claims 25whp with this valve. Get everything you need all in one shot.
I put enough slack in the vacuum tubing so that if you have a mounting point in a non-stock location it should still work for you.
$180
Sorry Pidass.. maybe a hour after I posted that ... someone in my local club posted a Turbosmart Dual Port for about the same price....so I'm taking it.
Good luck on the sale!
Status
