The thing is, with our car you already have pretty neutral handling. Understeer is mild, and with proper technique you can get the ass out pretty well. And the positioning of our drive wheels actually makes a big difference in this case. We will, in almost every situation, want more weight up front.
Imagine a corner entry with you trying to trail brake your way through to apex. Everything we're doing is up front - turning and braking, followed by the drive out of the corner. If you shift weight back to improve weight distribution, we will have less weight over the front end, which means less grip. This will mean less grip to spread around between braking and turning, which means one (or both) of those things is going to suffer. We'll take the corner slower, or more easily exceed the front brake limits and encounter understeer. The same holds true for the drive out.
In most performance vehicles, with the drive wheels at the back where they belong, under hard acceleration weight is shifted back and grip is improved at the rear where the power hits the road, and under hard braking weight is shifted forward and grip improved at the front where most of the braking is done. Our car has the problem that under hard acceleration weight, and therefor grip, moves away from the front, where we want it, under hard acceleration. I am not sure that, from a track performance perspective, the benefits of improving weight distribution would not be outweighed by the loss of front grip on corner exits.
Look at after market suspensions like Cobb, by the way. The drop tends to be greater in the front, and the rear suspension stiffer to prevent weight shift back, and I think this is probably why.
